Self signed SSL certs and designer in 8.3
Trust cert not working in designer.
I have checked:
So I deleted my SelfSigned Cert, I had HTTPS redirect ON.
No I cannot login to my Gateway. The HTTP port works, but I cannot login. It does login, the login form succeeds, but there is no logged in user afterwards.
Now I am stuck.
I did
./gwcmd.sh -i
Gateway Name: Ignition-opcpod
Gateway Version: 8.3.0 (64-bit)
Web Server Status: RUNNING
Gateway Status: RUNNING
Http Port: 12088
Https Port: 12043
./gwcmd.sh -p
Password has been reset. Gateway needs to be restarted.
./gwcmd.sh -r
Waiting for Gateway restart.
Gateway needs to be commissioned
I got at http port 12088 :
This site can’t provide a secure connection
10.246.30.91 sent an invalid response.
ERR_SSL_PROTOCOL_ERROR
./gwcmd.sh --clearks
Error! java.lang.Exception: Unable to clear the SSL key store caused by java.lang.IllegalArgumentException: State is NO_CERTIFICATE
Edit $IGNITION/data/gateway.xml and disable gateway.forceSecureRedirect:
<entry key="gateway.forceSecureRedirect">false</entry>
then restart and try to access your Ignition Gateway. Make sure you include "http", not "https", in the URL you use.
Thanks, https in address bar was one error.
I changed the setting and did a restart. I do log in in GW Web and after log in, no user is logged in :frowning:
cat data/gateway.xml
<properties>
<comment>Context Settings</comment>
<entry key="gateway.publicAddress.httpPort"></entry>
<entry key="gateway.publicAddress.autoDetect">true</entry>
<entry key="gateway.publicAddress.httpsPort"></entry>
<entry key="gateway.metroSSLPort">12060</entry>
<entry key="gateway.includedCipherSuites">[]</entry>
<entry key="localdb.autobackup.delay">60</entry>
<entry key="context.startup.useautobackups">true</entry>
<entry key="gateway.sslport">12043</entry>
<entry key="gateway.maxKeepAliveRequests">200</entry>
<entry key="context.props.version">3</entry>
<entry key="gateway.port">12088</entry>
<entry key="gateway.useProxyForwardedHeader">false</entry>
<entry key="localdb.autobackup.count">5</entry>
<entry key="gateway.maxThreads">300</entry>
<entry key="gateway.connectionTimeout">60000</entry>
<entry key="localdb.faultbackup.count">3</entry>
<entry key="gateway.resolveHostNames">false</entry>
<entry key="gateway.acceptCount">100</entry>
<entry key="gateway.keepAliveTimeout">60000</entry>
<entry key="gateway.excludedCipherSuites">[]</entry>
<entry key="gateway.publicAddress.address"></entry>
</properties>
./gwcmd.sh -r
Gateway is now running
I have a perspective project which requires login. Login screen appears, I login, same admin user. And a login screen comes up. I click Continue to login again, and login screen comes up. It seems a user is logged in, as login form no longer comes up, but it goes back to Continue to login as the login does not work.
It looks like some Chrome security feature. I have another gateway on another port. I set seflsigned cert there. I did not Force Secure Redirect, which probable saves me posibility to use designer.
But I cannot login to gw via http, only via https. Which complains about security. And does not save my password.
OK, i had to delete site data in chrome. Nice.
