Send Historical Data from Ignition API Server to an API-Client upon Get Request
Dear All , We want to examine the below if this is possible to be done with Ignition as API Server
So the main objective is to send Historical Data from our SQL database to a User . The User Will Request Data from Plants
Example
From Plant A : Specific Date query : Return the requested Values.
We would like to know the best path to follow.
Thanks in advance
Yes, this is one of the common uses of the WebbDev module.
Thank you Phil,
do you have any similar example or which steps we need to follow first so we do it right ?
