Has anyone managed to send messages to windows event log from script?
Thanks in advance!
Thanks in advance!
You could probably pair system.util.execute with the eventcreate builtin function: https://www.windows-commandline.com/create-event/
Keep in mind script execution scopes - if you call your script from a Vision button, it’ll go into the local machine’s logs, not the gateway’s; you’ll have to use something like system.util.sendMessage if you want to send an event to the gateway to go into a central event viewer.
I've tried that and the problem is that i need to run eventCreate via cmd which need to be run as administrator. That where it fails!
Hm, even from the gateway scope? I would expect the gateway service to be able to interact with it even when running as ‘LOCAL_SYSTEM’.
A bit of a hacky workaround:
I think I have to give up on this one, I’ve tried with elevated privileges and I get prompted “Do you allow this app to make changes”. Since I’m not allowed to turn off the notification in windows I assume it wont work.
Thanks for your efforts!
