I’m wondering if there is a good way to send emails to people who aren’t on specific rosters in an alarm pipeline. I wouldn’t mind editing the actual rosters but it doesn’t look like there is an easy scripting way to do that, and as far as I can tell you need to enter a roster name in the notification block. I think the only other way to do this is to use a script block, is that right?
As far as I know, yes. You can use calculated rosters in the alarm pipeline.
https://docs.inductiveautomation.com/display/DOC79/Notification+Block#NotificationBlock-Calculated
Oh, ok actually I like that a lot better, thanks!
There is quite a bit you can do with it. Good luck!
