Sending pdf in email
Hey, so I am trying to set up a report viewer to display a report, then have an option to send it off in an email. I have the report able to be set to a pdf viewer, I can also open it outside of Ignition. but when i try and send the email. i keep getting an error.
File “event:actionPerformed”, line 17, in
com.inductiveautomation.ignition.client.gateway_interface.GatewayException: com.inductiveautomation.ignition.client.gateway_interface.GatewayException: Error sending email.
caused by GatewayException: Error sending email.
caused by javax.mail.internet.ParseException: Expected MIME type, got null
#	The variables
title = event.source.parent.getComponent('Report Viewer').suggestedFilename
header = event.source.parent.getComponent('Report Viewer').suggestedFilename
sender = event.source.parent.noteTaker
reporter = system.db.runScalarQuery("SELECT Email FROM employee_names WHERE Name = '"+sender+"'")
emailList = ['stuart.drollinger@microgreeninc.com']
body = "This the process engineering report for "+sender
#	Creates the Attatchment to email out.
data = event.source.parent.getComponent('Report Viewer').bytesPDF
reportSet = system.file.getTempFile('.pdf')
system.file.writeFile(reportSet,data)
report = system.file.readFileAsBytes(reportSet)
#	Sends out the email
system.net.sendEmail(smtp='mail.microgreeninc.com',fromAddr = reporter, subject=header, body=body,html = 0, to = emailList, attachmentNames = [title], attachmentData = [report])
Thank you for any help you can offer me, i am kinda stuck at the moment.
[code]
The variables
title = event.source.parent.getComponent(‘Report Viewer’).suggestedFilename
header = event.source.parent.getComponent(‘Report Viewer’).suggestedFilename
reporter = system.db.runScalarQuery(“SELECT Email FROM employee_names WHERE Name = '”+sender+"’")
emailList = [‘stuart.drollinger@microgreeninc.com’]
data = event.source.parent.getComponent(‘Report Viewer’)
bytesPDF = data.getBytesPDF()
Sends out the email
system.net.sendEmail(smtp=‘mail.microgreeninc.com’,fromAddr = reporter, subject=header, body=body,html = 0, to = emailList, attachmentNames = [title], attachmentData = [bytesPDF])[/code]
try this
i still get that same error message, expected MIME Type, got null. its on the email line.
will the script send the email if you remove the attachmentname and attachment parameters?
yes it is sending the email, if i remove the attachments and title section of it.
Can you post the version of Ignition you’re using and the entire stack trace from the error?
File “event:actionPerformed”, line 15, in
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.newGatewayException(GatewayInterface.java:321)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:295)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendEmail(GatewayInterface.java:625)
at com.inductiveautomation.factorypmi.application.script.builtin.ClientNetUtilities._sendEmail(ClientNetUtilities.java:105)
at com.inductiveautomation.ignition.common.script.builtin.AbstractNetUtilities.sendEmail(AbstractNetUtilities.java:114)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.python.core.Py.JavaError(Py.java:495)
at com.inductiveautomation.factorypmi.application.script.builtin.ClientNetUtilities._sendEmail(ClientNetUtilities.java:108)
at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:186)
at com.inductiveautomation.ignition.common.script.ScriptManager$ReflectedInstanceFunction.__call__(ScriptManager.java:427)
at org.python.core.PyObject.__call__(PyObject.java:320)
at org.python.pycode._pyx50.f$0(<event:actionPerformed>:15)
at org.python.pycode._pyx50.call_function(<event:actionPerformed>)
at org.python.core.PyTableCode.call(PyTableCode.java:165)
at org.python.core.Py.runCode(Py.java:1275)
at com.inductiveautomation.ignition.common.script.ScriptManager.runCode(ScriptManager.java:568)
at com.inductiveautomation.factorypmi.application.binding.action.ActionAdapter.runActions(ActionAdapter.java:168)
at com.inductiveautomation.factorypmi.application.binding.action.ActionAdapter.invoke(ActionAdapter.java:265)
at com.inductiveautomation.factorypmi.application.binding.action.RelayInvocationHandler.invoke(RelayInvocationHandler.java:55)
at com.sun.proxy.$Proxy21.actionPerformed(Unknown Source)
at javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
at javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.setPressed(Unknown Source)
at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(Unknown Source)
at java.awt.Component.processMouseEvent(Unknown Source)
at javax.swing.JComponent.processMouseEvent(Unknown Source)
at java.awt.Component.processEvent(Unknown Source)
at java.awt.Container.processEvent(Unknown Source)
at java.awt.Component.dispatchEventImpl(Unknown Source)
at java.awt.Container.dispatchEventImpl(Unknown Source)
at java.awt.Component.dispatchEvent(Unknown Source)
at java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.processMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.dispatchEvent(Unknown Source)
at java.awt.Window.dispatchEventImpl(Unknown Source)
at java.awt.EventQueue.access$500(Unknown Source)
at java.awt.EventQueue$3.run(Unknown Source)
at java.security.ProtectionDomain$1.doIntersectionPrivilege(Unknown Source)
at java.awt.EventQueue$4.run(Unknown Source)
Caused by: com.inductiveautomation.ignition.client.gateway_interface.GatewayException: Error sending email.
… 54 more
Caused by: javax.mail.internet.ParseException: Expected MIME type, got null
at javax.mail.internet.ContentType.(ContentType.java:95)
at javax.mail.internet.MimeBodyPart.updateHeaders(MimeBodyPart.java:1331)
at javax.mail.internet.MimeBodyPart.updateHeaders(MimeBodyPart.java:1021)
at javax.mail.internet.MimeMultipart.updateHeaders(MimeMultipart.java:419)
at javax.mail.internet.MimeBodyPart.updateHeaders(MimeBodyPart.java:1354)
at javax.mail.internet.MimeMessage.updateHeaders(MimeMessage.java:2107)
at javax.mail.internet.MimeMessage.saveChanges(MimeMessage.java:2075)
at javax.mail.Transport.send(Transport.java:123)
at com.inductiveautomation.ignition.gateway.script.GatewayNetUtilities.sendEmail(GatewayNetUtilities.java:151)
at com.inductiveautomation.ignition.gateway.servlets.Gateway._sendEmail(Gateway.java:968)
at com.inductiveautomation.ignition.gateway.servlets.Gateway.doPost(Gateway.java:393)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:790)
at com.inductiveautomation.ignition.gateway.bootstrap.MapServlet.service(MapServlet.java:85)
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:696)
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:526)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143)
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:568)
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:221)
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1110)
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:453)
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:183)
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1044)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141)
at org.eclipse.jetty.server.handler.HandlerList.handle(HandlerList.java:52)
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:97)
at org.eclipse.jetty.server.Server.handle(Server.java:459)
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:280)
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:229)
at org.eclipse.jetty.io.AbstractConnection$1.run(AbstractConnection.java:505)
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:607)
at org.eclipse.jetty.util.thread.QueuedThreadPool$3.run(QueuedThreadPool.java:536)
at java.lang.Thread.run(null)
Ignition v7.7.1 (b2014092209)
Java: Oracle Corporation 1.8.0_31
Ignition Version 7.7.1 (b2014092209)
Java Version Oracle Corporation 1.8.0_11
Derp, this exact same thing tripped me up a couple of weeks ago. This time, I need to make a note for our documentation people.
Attachements are super dependent on having the right file extensions in the name. If you add “.pdf” (without the quotes, obviously) to the end of your filename, you should find all is well.
Old Code
#   The variables
bytesPDF = event.source.parent.getComponent('Report Viewer').getBytesPDF()
system.net.sendEmail(smtp='mail.microgreeninc.com',fromAddr = reporter, subject=header, body=body,html = 0, to = emailList, attachmentNames = [title], attachmentData = [bytesPDF])
New Code
#   The variables
bytesPDF = bytesPDF + '.pdf'
or how do i add the file extension to that?
Use the old code, and add a line that says
title = title + '.pdf'
We just need to change the name of the attachment, not the attachment itself.
awesome. Thank you. that worked perfectly.
