SentinelOne Security Agent
We have a separate IT department that manages all of our computers. They install “SentinelOne” software on our SCADA Server a few weeks back. Now everything was working up until yesterday when and update caused the server to reboot and now the Gateway will not start.
Has anybody else every had a problem with this program? SentinelOne
Things seemed to work when IT installed it on our servers, but we’ve since had exceptions to live scanning added for Ignition folder (including internal DB, local historian data, etc.). We did run into some issues with Rockwell PLCs going offline around the same time, but are not certain if that had anything to do with the SentinelOne install–suspect it may have been duplicate IPs on the network as there was an issue with DHCP server config discovered soon after.
Thanks for the reply. I’m still trying to figure out what happened, Ignition support is helping.
@dcamp1. What version of SentinelOne are you using?
I’m sorry but I am out of the office and won’t be back until Tuesday. However I will check and post then.
@dcamp1 What version of SentinalOne are you running?
Thanks I did forget about this.
We are using version 4.6.13.298
Did you get the Gateway started?
What OS is running on the server?
Yes, This has been taken care and it was not the fault of SentinelOne.
I am on Windows 10 Pro.
Thank you!
