Hi, I installed a fresh gateway and added Sepasoft OEE and Production modules. Configured database and it is ok. Imported a project from another gateway that was already working, but when opening Designer the Sepasoft components for Vision and Perspective are not available. Only the report ones.
At some point I could see the components running in the perspective session, but then they dissappeared again.
I have restarted the services and reinstalled them a few times but won't show up. Also uninstalled the designer launcher and installed again after Sepasoft modules were installed with same negative result. Ignition 8.1.43 and Sepasoft 3.81.10 SP6. Thanks. @jesse.records
