I have installed the OEE and Production modules and they seem to work fine with production simulator. I am able to work on equipment manager and create and edit my equipment tree. However, there is a “New” button under Additional Factors and Live Analysis settings that is supposed to open a modal to enter new data and is NOT working. I have reinstalled the modules several times and restarted the PC. In another machine I have no issue. Any ideas why this could be happening?
I am running Gateway 8.1.13 and MES modules 3.81.4-rc2
Are you seeing errors in the console when you click on it?
EDIT: oh actually, the button doesn’t work for me either. I’m running Ignition 8.1.13 and Sepasoft 3.81.2.
I get this in the console: java.lang.NoClassDefFoundError.
Better create a ticket on Sepasoft.com
8.1.12 is the highest tested version from Sepasoft for 3.81.2 on the downloads page.
We are investigating the java.lang.NoClassDefFoundError issue in 8.1.13.
Thanks Jesse and G for looking into this.
By using the Equipment Manager component on Perspective (which is available in 3.81.4-rc2) I am able to create the Live Analysis and Additional factors, but once I navigate into any of these sections, I see no button or way to navigate back out of them. Am I doing something wrong? or it’s because it’s still a RC?
Daniel, Sepasoft support said the bug is known but it’s only with Ignition 8.1.13. They suggest you downgrade to Ignition 8.1.12 for the time being while awaiting for a bugfix.
I know you said you were running 8.1.12, but I just tested the bug in Ignition 8.1.12 and I’m not seeing it, so I’m assuming you reported the wrong Ignition version.
As for the perspective component, I’ll check later
G you are right. I did so many things that my brain just stopped working. You are right. I had 8.1.13 (I edited my original post to make this thread useful for other people later) Downgraded to 8.1.12 and it works fine. Thanks a lot.
