Sepasoft Module Faulted
I tried installing Sepasoft’s OEE module (Compatible with 8.1.7) into Ignition 8.1.7.
It shows an errored state. Could you help me to find out the problem?
You must also install the Production Module, it is required by all other modules before they will run.
Production 2.81.0 (b2112272059) (SP-16) A module that provides the core MES production model functionality with task routing.
