I didn’t see much along the lines of these errors on the forum that pointed to a relevant cause. Does anyone have any ideas on what may be causing these intermittent errors? They aren’t too often, but they are scattered throughout the logs and I wanted to try and address them.
What version of Ignition is this happening on?
8.0.2 Release ( 8.0.2 (b2019060511))
Okay, I think this might be fixed in 8.0.3, which includes a newer version of the OPC UA SDK that has a fix for a bug that looks a lot like this.
In the meantime, you don’t need to worry too much because the ResendData call is succeeding and you aren’t losing any realtime values.
Ok thanks. I’ll update the system once the 8.0.3 release comes out and see what happens
