Hi!
I am having some problems to connect Ignition to a Mitsubishi A system PLC via serial COM port communication.
The set-up looks like this:
PLC serial module - Moxa RS232/TCPIP - Moxa Nport (convertion to COM) - SCADA
This setup is running with the old scada.
Can both scada use the same COM port?
I have tested disconnect the old scada and connect using Kepware Mitsubishi serial driver as a hub but with no success.
Thanks!
