Serial Communications in Ignition with Arduino
Here is a new blog post that shows an example of using the Serial Support Client Module to communicate to a serial device in Ignition: http://blog.perfectabstractions.com/2017/03/29/serial-communications-in-ignition-with-arduino/
Good night. I have this error:
File “event:propertyChange”, line 3, in
File “module:project.serial”, line 25, in updateSerialTag
File “module:project.serial”, line 7, in openSerialPort
AttributeError: ‘com.inductiveautomation.ignition.common.script.Imm’ object has no attribute ‘serial’
at org.python.core.Py.AttributeError(Py.java:173)
at org.python.core.PyObject.noAttributeError(PyObject.java:930)
at org.python.core.PyObject.__getattr__(PyObject.java:925)
at org.python.pycode._pyx1.openSerialPort$1(<module:project.serial>:11)
at org.python.pycode._pyx1.call_function(<module:project.serial>)
at org.python.core.PyTableCode.call(PyTableCode.java:165)
at org.python.core.PyBaseCode.call(PyBaseCode.java:149)
at org.python.core.PyFunction.__call__(PyFunction.java:327)
at org.python.pycode._pyx1.updateSerialTag$3(<module:project.serial>:29)
at org.python.core.PyBaseCode.call(PyBaseCode.java:166)
at org.python.core.PyFunction.__call__(PyFunction.java:338)
at org.python.pycode._pyx0.f$0(<event:propertyChange>:3)
at org.python.pycode._pyx0.call_function(<event:propertyChange>)
at org.python.core.Py.runCode(Py.java:1275)
at com.inductiveautomation.ignition.common.script.ScriptManager.runCode(ScriptManager.java:634)
at com.inductiveautomation.factorypmi.application.binding.action.ActionAdapter.runActions(ActionAdapter.java:180)
at com.inductiveautomation.factorypmi.application.binding.action.ActionAdapter.access$000(ActionAdapter.java:40)
at com.inductiveautomation.factorypmi.application.binding.action.ActionAdapter$ActionRunner.run(ActionAdapter.java:286)
at java.awt.event.InvocationEvent.dispatch(Unknown Source)
at java.awt.EventQueue.access$500(Unknown Source)
at java.awt.EventQueue$3.run(Unknown Source)
at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(Unknown Source)
Ignition v7.9.6 (b2018012914)
Java: Oracle Corporation 1.8.0_111
That generally means the module isn’t installed…
thanks my friend, it served me a lot
