Serialization Error from Template
Hello,
I am getting an error I have never seen before. As well as throwing Null pointer exceptions. Any idea as to why this is happening? I believe it is coming from my template repeater. I have a hunch its due to some indirect tag bindings but I am still experimenting with that idea.
com.inductiveautomation.ignition.common.xmlserialization.SerializationException: Error during serialization for property 'interactionController' on object '[FPMIWindow]PIDControlVTIS'
	at com.inductiveautomation.ignition.common.xmlserialization.serialization.DefaultObjectSerializationDelegate.serializeProperties(DefaultObjectSerializationDelegate.java:307)
	at com.inductiveautomation.factorypmi.designer.xmlserialization.WindowDelegate.serialize(WindowDelegate.java:34)
	at com.inductiveautomation.ignition.common.xmlserialization.serialization.XMLSerializationContext.serialize(XMLSerializationContext.java:49)
	at com.inductiveautomation.ignition.common.xmlserialization.serialization.XMLSerializer.serialize(XMLSerializer.java:525)
	at com.inductiveautomation.ignition.common.xmlserialization.serialization.XMLSerializer.serializeBinary(XMLSerializer.java:507)
	at com.inductiveautomation.factorypmi.designer.workspace.WindowWorkspace.saveContainer(WindowWorkspace.java:1605)
	at com.inductiveautomation.factorypmi.designer.workspace.WindowWorkspace.commitDesignable(WindowWorkspace.java:1314)
	at com.inductiveautomation.factorypmi.designer.workspace.WindowWorkspace.commitAll(WindowWorkspace.java:883)
	at com.inductiveautomation.factorypmi.designer.model.VisionDesignerImpl.notifyProjectSaveStart(VisionDesignerImpl.java:552)
	at com.inductiveautomation.ignition.designer.IgnitionDesigner.commitAll(IgnitionDesigner.java:1581)
	at com.inductiveautomation.ignition.designer.IgnitionDesigner.handleSave(IgnitionDesigner.java:1347)
	at com.inductiveautomation.ignition.designer.IgnitionDesigner$Handler.handleSaveAction(IgnitionDesigner.java:2750)
	at com.inductiveautomation.ignition.designer.IgnitionDesigner$Handler$5.actionPerformed(IgnitionDesigner.java:2338)
	at java.desktop/javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
	at java.desktop/javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source)
	at java.desktop/javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
	at java.desktop/javax.swing.DefaultButtonModel.setPressed(Unknown Source)
	at java.desktop/javax.swing.plaf.basic.BasicButtonListener.mouseReleased(Unknown Source)
	at com.jidesoft.plaf.basic.BasicJideButtonListener.mouseReleased(Unknown Source)
	at java.desktop/java.awt.AWTEventMulticaster.mouseReleased(Unknown Source)
	at java.desktop/java.awt.EventQueue$5.run(Unknown Source)
Caused by: com.inductiveautomation.ignition.common.xmlserialization.SerializationException: Error during serialization for property 'propertyAdapters' on object '[DefaultInteractionController]com.inductiveautomation.factorypmi.application.binding.DefaultInteractionController@13705862'
	at com.inductiveautomation.ignition.common.xmlserialization.serialization.DefaultObjectSerializationDelegate.serialize(DefaultObjectSerializationDelegate.java:334)
	at com.inductiveautomation.ignition.common.xmlserialization.serialization.DefaultObjectSerializationDelegate.writeCall(DefaultObjectSerializationDelegate.java:240)
	at com.inductiveautomation.ignition.common.xmlserialization.serialization.DefaultObjectSerializationDelegate.writeCall(DefaultObjectSerializationDelegate.java:227)
	at com.inductiveautomation.ignition.common.xmlserialization.serialization.DefaultObjectSerializationDelegate.doProperty(DefaultObjectSerializationDelegate.java:284)
	at com.inductiveautomation.ignition.common.xmlserialization.serialization.DefaultObjectSerializationDelegate.serializeProperties(DefaultObjectSerializationDelegate.java:305)
	... 49 more
Caused by: com.inductiveautomation.ignition.common.xmlserialization.SerializationException: Error during serialization for property 'expression' on object '[ExpressionPropertyAdapter][Root Container, Replay Controller, Root Container, Root Container] ---> SP_Fill'
	at com.inductiveautomation.ignition.common.xmlserialization.serialization.delegates.MapDelegate.serializeElements(MapDelegate.java:43)
	at com.inductiveautomation.ignition.common.xmlserialization.serialization.delegates.MapDelegate.serialize(MapDelegate.java:33)
	... 55 more
Caused by: com.inductiveautomation.ignition.common.xmlserialization.SerializationException: Error during serialization for property 'children' on object '[FunctionExpression]com.inductiveautomation.ignition.common.expressions.FunctionExpression@338f01ab'
	... 66 more
Caused by: com.inductiveautomation.ignition.common.xmlserialization.SerializationException: Error during serialization for property 'children' on object '[ArithmeticExpression]com.inductiveautomation.ignition.common.expressions.ArithmeticExpression@991f0ea'
	at com.inductiveautomation.ignition.common.xmlserialization.serialization.delegates.ArrayDelegate.serialize(ArrayDelegate.java:30)
	... 72 more
Caused by: com.inductiveautomation.ignition.common.xmlserialization.SerializationException: Error during serialization for property 'children' on object '[ArithmeticExpression]com.inductiveautomation.ignition.common.expressions.ArithmeticExpression@1d5e2369'
	... 80 more
Caused by: com.inductiveautomation.ignition.common.xmlserialization.SerializationException: Error during serialization for property 'children' on object '[ArithmeticExpression]com.inductiveautomation.ignition.common.expressions.ArithmeticExpression@1eacef5c'
	... 88 more
Caused by: com.inductiveautomation.ignition.common.xmlserialization.SerializationException: Error during serialization for property 'propertyListener' on object '[BoundVariableExpression]com.inductiveautomation.factorypmi.application.binding.expression.BoundVariableExpression@7285c28b'
	... 96 more
Caused by: com.inductiveautomation.ignition.common.xmlserialization.SerializationException: Error during serialization for property 'source' on object '[PropertyListenerDescriptor][PLD Listener on Root Container.PID::Maximum ([null, Bad_Stale, Sat Sep 14 09:51:18 MST 2024 (1726332678286)])]'
	... 104 more
Caused by: com.inductiveautomation.ignition.common.xmlserialization.SerializationException: Error during serialization for property 'value' on object '[DynamicPropertyDescriptor]SetPointDataset'
	at com.inductiveautomation.ignition.common.xmlserialization.serialization.delegates.TreeMapDelegate.serialize(TreeMapDelegate.java:25)
	at com.inductiveautomation.factorypmi.designer.xmlserialization.BasicContainerDelegate.serializeProperties(BasicContainerDelegate.java:60)
	at com.inductiveautomation.factorypmi.designer.xmlserialization.BasicContainerDelegate.serialize(BasicContainerDelegate.java:45)
	at com.inductiveautomation.factorypmi.designer.xmlserialization.InteractionDescriptorDelegate.doProperty(InteractionDescriptorDelegate.java:40)
	... 110 more
Caused by: com.inductiveautomation.ignition.common.xmlserialization.SerializationException: Unable to create clean copy of class com.inductiveautomation.ignition.common.script.builtin.ialabs.BrowseTag
	at com.inductiveautomation.ignition.common.xmlserialization.serialization.XMLSerializer.getCleanCopy(XMLSerializer.java:591)
	at com.inductiveautomation.ignition.common.xmlserialization.serialization.XMLSerializationContext.getCleanCopy(XMLSerializationContext.java:71)
	at com.inductiveautomation.ignition.common.xmlserialization.serialization.DefaultObjectSerializationDelegate.serializeProperties(DefaultObjectSerializationDelegate.java:297)
	at com.inductiveautomation.ignition.common.xmlserialization.serialization.DefaultObjectSerializationDelegate.writeConstructor(DefaultObjectSerializationDelegate.java:381)
	at com.inductiveautomation.ignition.common.xmlserialization.serialization.DefaultObjectSerializationDelegate.serializeConstructor(DefaultObjectSerializationDelegate.java:372)
	at com.inductiveautomation.ignition.common.xmlserialization.serialization.DefaultObjectSerializationDelegate.serialize(DefaultObjectSerializationDelegate.java:330)
	... 126 more
Ignition v8.0.17 (b2020111211)
Java: Azul Systems, Inc. 11.0.7
Here is the Null Pointer Exception:
java.lang.NullPointerException
	at com.inductiveautomation.factorypmi.designer.model.navtree.TemplateNode.findChild(TemplateNode.java:245)
	at com.inductiveautomation.factorypmi.designer.model.navtree.AbstractTopLevelContainerNode.handleSelectedItemsChanged(AbstractTopLevelContainerNode.java:211)
	at com.inductiveautomation.factorypmi.designer.model.navtree.AbstractTopLevelContainerNode.itemSelectionChanged(AbstractTopLevelContainerNode.java:156)
	at com.inductiveautomation.ignition.designer.designable.AbstractDesignableWorkspace.fireSelectedItemsChanged(AbstractDesignableWorkspace.java:305)
	at com.inductiveautomation.ignition.designer.designable.AbstractDesignableWorkspace.setSelectedItems(AbstractDesignableWorkspace.java:288)
	at com.inductiveautomation.ignition.designer.designable.AbstractDesignableWorkspace.setSelectedItems(AbstractDesignableWorkspace.java:264)
	at com.inductiveautomation.ignition.designer.designable.AbstractDesignableWorkspace.lambda$new$0(AbstractDesignableWorkspace.java:137)
	at java.desktop/javax.swing.DefaultSingleSelectionModel.fireStateChanged(Unknown Source)
	at com.jidesoft.swing.JideTabbedPane$IgnoreableSingleSelectionModel.fireStateChanged(Unknown Source)
	at java.desktop/javax.swing.DefaultSingleSelectionModel.setSelectedIndex(Unknown Source)
	at java.desktop/javax.swing.JTabbedPane.setSelectedIndexImpl(Unknown Source)
	at java.desktop/javax.swing.JTabbedPane.setSelectedIndex(Unknown Source)
	at com.jidesoft.swing.JideTabbedPane.setSelectedIndex(Unknown Source)
	at java.desktop/javax.swing.JTabbedPane.setSelectedComponent(Unknown Source)
	at com.inductiveautomation.ignition.designer.designable.AbstractDesignableWorkspace.open(AbstractDesignableWorkspace.java:431)
	at com.inductiveautomation.factorypmi.designer.workspace.WindowWorkspace.openTemplate(WindowWorkspace.java:1883)
	at com.inductiveautomation.factorypmi.designer.model.VisionDesignerImpl$DesignableProjectListener.updateResources(VisionDesignerImpl.java:1717)
	at com.inductiveautomation.factorypmi.designer.model.VisionDesignerImpl$DesignableProjectListener.resourcesModified(VisionDesignerImpl.java:1662)
	at com.inductiveautomation.ignition.common.project.AbstractProject.notifyResourceListeners(AbstractProject.java:351)
	at com.inductiveautomation.ignition.common.project.AbstractProject.updateEffectiveState(AbstractProject.java:153)
	at com.inductiveautomation.ignition.designer.project.DesignerProjectTreeImpl.modifyResource(DesignerProjectTreeImpl.java:174)
	at com.inductiveautomation.ignition.designer.project.DesignableProject.createOrModify(DesignableProject.java:160)
	at com.inductiveautomation.factorypmi.designer.workspace.WindowWorkspace.saveContainer(WindowWorkspace.java:1612)
	at com.inductiveautomation.factorypmi.designer.workspace.WindowWorkspace$TemplateCommitter.containerSelected(WindowWorkspace.java:3595)
	at com.inductiveautomation.ignition.designer.designable.AbstractDesignableWorkspace.lambda$new$0(AbstractDesignableWorkspace.java:133)
	at com.jidesoft.plaf.basic.BasicJideTabbedPaneUI$MouseHandler.mousePressed(Unknown Source)
	at java.desktop/java.awt.AWTEventMulticaster.mousePressed(Unknown Source)
You have an expression binding on SP_Fill that is yielding an object that cannot be stored with the window/template. Show us that expression. (Use the forum's preformatted text button to preserve your expression's format.)
[ my flight is taking off shortly.... others may have to continue this with you. ]
Hi Phil,
I got rid of the expression that was there:
if({[Client]Replay/UseHistory},
292*({Root Container.PID::Maximum}-{Root Container.Container.Replay Controller.SP})/({Root Container.PID::Maximum}-{Root Container.PID::Minimum}),
292*({Root Container.PID::Maximum}-{Root Container.PID::SP})/({Root Container.PID::Maximum}-{Root Container.PID::Minimum}))
I will still need a version of this but I am not passing in any parameters to this window portion of the window just yet. I am only trying to test my template repeater. I thought it was the template repeater but it must of been the parameters that the bindings were looking for that were not there yet.
Thanks Phil!
My template is not out of the woods yet, I wish I could screenshot what's happening right now. I just had 384 null pointer exception errors.
This error only occurs when I try to open the template window. The template repeater works but opening the template causes this error.
I am going to do some more experimenting. The template is pretty simple with only indirect bindings used. This problem is intermittent, and doesn't happen every time I open the window. I think we solved the first serialization error but I'll keep an eye on this null pointer exception.
:frowning: I have to recant my statement. Here is the new serialization error:
	at com.inductiveautomation.ignition.designer.IgnitionDesigner$Handler.handleUpdate(IgnitionDesigner.java:2788)
	at com.inductiveautomation.ignition.designer.IgnitionDesigner.updateProject(IgnitionDesigner.java:1124)
	at com.inductiveautomation.ignition.designer.concurrency.ui.ConcurrencyUiManager.lambda$new$0(ConcurrencyUiManager.java:36)
	at com.inductiveautomation.ignition.client.util.gui.Listen.lambda$toAction$2(Listen.java:41)
Caused by: com.inductiveautomation.ignition.common.xmlserialization.SerializationException: Error during serialization for property 'propertyAdapters' on object '[DefaultInteractionController]com.inductiveautomation.factorypmi.application.binding.DefaultInteractionController@2921dad0'
	... 48 more
Caused by: com.inductiveautomation.ignition.common.xmlserialization.SerializationException: Error during serialization for property 'updates' on object '[CellUpdateAdapter][Root Container, Root Container, Root Container, Root Container, Root Container] ---> Replay Controller'
	... 54 more
Caused by: com.inductiveautomation.ignition.common.xmlserialization.SerializationException: Error during serialization for property 'value' on object '[CellUpdateSpec]com.inductiveautomation.factorypmi.application.binding.CellUpdateAdapter$CellUpdateSpec@40fdf92f'
	at com.inductiveautomation.ignition.common.xmlserialization.serialization.delegates.ArrayListDelegate.serialize(ArrayListDelegate.java:23)
	at com.inductiveautomation.ignition.common.xmlserialization.serialization.delegates.ArrayListDelegate.serialize(ArrayListDelegate.java:17)
	... 65 more
Caused by: com.inductiveautomation.ignition.common.xmlserialization.SerializationException: Error during serialization for property 'nodes' on object '[QueryHolder]com.inductiveautomation.factorypmi.application.binding.QueryHolder@6c6566bb'
	... 74 more
Caused by: com.inductiveautomation.ignition.common.xmlserialization.SerializationException: Error during serialization for property 'property' on object '[QueryNode]VTIS/VTIS1/PID/LC008'
	... 80 more
Caused by: com.inductiveautomation.ignition.common.xmlserialization.SerializationException: Error during serialization for property 'source' on object '[PropertyListenerDescriptor][PLD Listener on Root Container.PIDTagPath ([VTIS/VTIS1/PID/LC008, Good, Sat Sep 14 09:55:13 MST 2024 (1726332913023)])]'
	... 88 more
	... 94 more
	... 110 more
