SerializationException error
I am trying to open one screen from the demo proiect that I downloaded from Sepasoft website. The screen has MES Equipment Manager component .
But I see below error. Any idea what is this? And how to resolve?
I am using Ignition v 8.1.18 with the prodcution module (from Sepasoft) at 3.81.5
I restarted the project, restarted the PC, tried to add same component on new screen, but nothing has worked so far…
Error is:
SerializationException: Error deserializing element “<c”
caused by GatewayException: Try request again once production model has started. Use system.mes.isProductionStarted()
caused by IllegalStateException: Try request again once production model has started. Use system.mes.isProductionStarted()
Log from Wrapper
INFO | jvm 1 | 2022/07/13 12:55:23 | I [c.s.p.m.m.MESObjectManager ] [07:25:23]: Automatically synchronized MES Personnel with Ignition users.
INFO | jvm 1 | 2022/07/13 13:32:56 | I [g.LicenseManager ] [08:02:56]: Trial time reset. Time remaining = 7200. route-group=status, route-path=/trial
INFO | jvm 1 | 2022/07/13 13:32:56 | I [s.ProjectRunner ] [08:02:56]: Setting SQL Bridge project enabled state to ‘ENABLED’ project-name=MESGateway, module-name=SQL Bridge
INFO | jvm 1 | 2022/07/13 13:32:56 | I [s.ProjectRunner ] [08:02:56]: Setting SQL Bridge project enabled state to ‘ENABLED’ module-name=SQL Bridge, project-name=BatchStarter_20211021160546
INFO | jvm 1 | 2022/07/13 13:33:08 | I [P.InternalDatabase ] [08:03:08]: Creating auto-backup of internal database “config.idb”…
INFO | jvm 1 | 2022/07/13 13:33:09 | I [P.InternalDatabase ] [08:03:09]: Created auto-backup of internal database “config.idb” in 920 ms
INFO | jvm 1 | 2022/07/13 13:35:18 | W [ClockDriftDetector ] [08:05:18]: Clock drift, degraded performance, or pause-the-world detected.
INFO | jvm 1 | 2022/07/13 13:35:18 | Max allowed deviation=1000ms, actual deviation=2141ms
INFO | jvm 1 | 2022/07/13 13:35:53 | Jul 13, 2022 1:35:52 PM com.google.inject.internal.ProxyFactory
INFO | jvm 1 | 2022/07/13 13:35:53 | WARNING: Method [public java.util.List com.sepasoft.production.gateway.ProductionRPCHandler.getTopLevelLinks(java.util.Set) throws java.lang.Exception] is synthetic and is being intercepted by [com.sepasoft.production.gateway.interceptor.BlockUntilReadyInterceptor@34774d9c]. This could indicate a bug. The method may be intercepted twice, or may not be intercepted at all.
INFO | jvm 1 | 2022/07/13 13:35:53 | Jul 13, 2022 1:35:53 PM com.google.inject.internal.ProxyFactory
INFO | jvm 1 | 2022/07/13 13:35:53 | WARNING: Method [public java.util.List com.sepasoft.production.gateway.ProductionRPCHandler.getMESObjectChildLinks(com.sepasoft.production.common.model.mesobject.misc.MESObjectFilter) throws java.lang.Exception] is synthetic and is being intercepted by [com.sepasoft.production.gateway.interceptor.BlockUntilReadyInterceptor@34774d9c]. This could indicate a bug. The method may be intercepted twice, or may not be intercepted at all.
INFO | jvm 1 | 2022/07/13 13:35:53 | WARNING: Method [public java.util.List com.sepasoft.production.gateway.ProductionRPCHandler.getMESObjectChildLinks(com.sepasoft.production.common.model.mesobject.core.MESObjectLink,java.util.List,java.lang.Boolean,java.lang.Boolean) throws java.lang.Exception] is synthetic and is being intercepted by [com.sepasoft.production.gateway.interceptor.BlockUntilReadyInterceptor@34774d9c]. This could indicate a bug. The method may be intercepted twice, or may not be intercepted at all.
INFO | jvm 1 | 2022/07/13 13:35:53 | WARNING: Method [public java.util.List com.sepasoft.production.gateway.ProductionRPCHandler.getMESObjectChildLinks(com.sepasoft.production.common.model.mesobject.core.MESObjectLink,java.util.List,java.lang.Boolean) throws java.lang.Exception] is synthetic and is being intercepted by [com.sepasoft.production.gateway.interceptor.BlockUntilReadyInterceptor@34774d9c]. This could indicate a bug. The method may be intercepted twice, or may not be intercepted at all.
Looks like a Sepasoft bug. You should contact their support.
Thank you Phil. I sent a note to Sepasoft
Is there a way I can tag them on this post here?
I know this is an old thread but wondering if a solution was ever found. I am currently having the same issue.
