hazey
January 27, 2010, 11:43am
1
Guys I am getting a fault trying to start Ignition.
Fault is
The Ignition Gateway service is starting.The Ignition Gateway service could not be started.The service did not report an error.More help is available by typing NET HELPMSG3534.
What is cauising this?
thanks
Hazey
Hi-
There is a log file in the install directory called “wrapper.log”. This file should offer some better information as to the error that’s occurring.
Take a look, it might be something obvious like “port already in use”, indicating that a different application is running on port 8088, and that the port needs to be changed from the gateway control utility.
If it’s not something obvious, could you post the file here as an attachment?
Regards,
hazey
January 27, 2010, 9:20pm
3
Wrapper info below…upload would not allow file attachment.
STATUS | wrapper | 2010/01/28 07:08:31 | Ignition Gateway installed.
STATUS | wrapper | 2010/01/28 07:09:32 | Starting the Ignition Gateway service…
STATUS | wrapper | 2010/01/28 07:09:32 | --> Wrapper Started as Service
STATUS | wrapper | 2010/01/28 07:09:32 | Java Service Wrapper Standard Edition 32-bit 3.3.9
STATUS | wrapper | 2010/01/28 07:09:32 | Copyright © 1999-2009 Tanuki Software, Ltd. All Rights Reserved.
STATUS | wrapper | 2010/01/28 07:09:32 | wrapper.tanukisoftware.org
ERROR | wrapper | 2010/01/28 07:09:32 | License Error:
ERROR | wrapper | 2010/01/28 07:09:32 | The license keys are incorrect.
ERROR | wrapper | 2010/01/28 07:09:32 | Please verify that the wrapper.license.* properties match exactly
ERROR | wrapper | 2010/01/28 07:09:32 | and that the following property values match those required for the license:
ERROR | wrapper | 2010/01/28 07:09:32 | wrapper.java.mainclass=org.tanukisoftware.wrapper.WrapperSimpleApp
ERROR | wrapper | 2010/01/28 07:09:32 | wrapper.app.parameter.1=com.inductiveautomation.catapult.Catapult
ERROR | wrapper | 2010/01/28 07:09:32 | A license can be obtained from the Java Service Wrapper site:
ERROR | wrapper | 2010/01/28 07:09:32 | wrapper.tanukisoftware.org/doc/e … chase.html
ERROR | wrapper | 2010/01/28 07:09:32 | Licenses can be generated for any of the following Host Ids.
ERROR | wrapper | 2010/01/28 07:09:32 | The first Host Id is recommended.
ERROR | wrapper | 2010/01/28 07:09:32 | Host Ids:
ERROR | wrapper | 2010/01/28 07:09:32 | 0019d1a03c36 (#1 )
ERROR | wrapper | 2010/01/28 07:09:32 | Optional host name for license: DMH
STATUS | wrapper | 2010/01/28 07:09:32 | <-- Wrapper Stopped
ERROR | wrapper | 2010/01/28 07:09:34 | The Ignition Gateway service was launched, but failed to start.
STATUS | wrapper | 2010/01/28 07:11:47 | --> Wrapper Started as Service
STATUS | wrapper | 2010/01/28 07:11:47 | Java Service Wrapper Standard Edition 32-bit 3.3.9
STATUS | wrapper | 2010/01/28 07:11:47 | Copyright © 1999-2009 Tanuki Software, Ltd. All Rights Reserved.
STATUS | wrapper | 2010/01/28 07:11:47 | wrapper.tanukisoftware.org
ERROR | wrapper | 2010/01/28 07:11:47 | License Error:
ERROR | wrapper | 2010/01/28 07:11:47 | The license keys are incorrect.
ERROR | wrapper | 2010/01/28 07:11:47 | Please verify that the wrapper.license.* properties match exactly
ERROR | wrapper | 2010/01/28 07:11:47 | and that the following property values match those required for the license:
ERROR | wrapper | 2010/01/28 07:11:47 | wrapper.java.mainclass=org.tanukisoftware.wrapper.WrapperSimpleApp
ERROR | wrapper | 2010/01/28 07:11:47 | wrapper.app.parameter.1=com.inductiveautomation.catapult.Catapult
ERROR | wrapper | 2010/01/28 07:11:47 | A license can be obtained from the Java Service Wrapper site:
ERROR | wrapper | 2010/01/28 07:11:47 | wrapper.tanukisoftware.org/doc/e … chase.html
ERROR | wrapper | 2010/01/28 07:11:47 | Licenses can be generated for any of the following Host Ids.
ERROR | wrapper | 2010/01/28 07:11:47 | The first Host Id is recommended.
ERROR | wrapper | 2010/01/28 07:11:47 | Host Ids:
ERROR | wrapper | 2010/01/28 07:11:47 | 0019d1a03c36 (#1 )
ERROR | wrapper | 2010/01/28 07:11:47 | Optional host name for license: DMH
STATUS | wrapper | 2010/01/28 07:11:47 | <-- Wrapper Stopped
thanks
hazey
Hazey,
Can you verify that you have both ignition.conf and wrapper-license.conf in your installation directory (C:\Program Files\Inductive Automation\Ignition by default) and email them to me?
kevin inductiveautomation com
OK, I’ve sent you and another person who emailed me with the same problem new wrapper-license.conf files to replace your existing ones.
It turns out there’s a bug in the service wrapper software the affects machines with a Timezone east of Japan, including Eastern Australia, New Zealand, and the island states.
Both people who contacted me with issues happened to be from Australia so I think this will solve the problem.
I am posting the contents of the new wrapper-license.conf file in case anybody else runs into this issue.
wrapper.license.type=DEV
wrapper.license.id=200912060002
wrapper.license.licensee=Inductive Automation
wrapper.license.dev_application=Ignition Gateway
wrapper.license.features=64bit
wrapper.license.key.0=4af2-e870-4cd4-1bf0
wrapper.license.key.1=ea73-894a-345b-8a3e
wrapper.license.key.2=d792-3631-0388-0165
wrapper.license.key.3=5d18-ad0e-78a9-c878
wrapper.license.key.4=66ca-7432-8e30-36f7
