Hello,
this night our Ignition server stopped working. The cause for the fault was most problably the logfile maintenance with a logger setting to debug. The wrapper detected a problem with the JVM but failed to restart it. From the log i guess there was a timeout expiring.
Are the any settings in the wrapper configuration to optimize this behaviour?
Ignition version is 8.1.7 running on Debian Linux 10.
INFO | jvm 2 | 2021/07/30 00:12:50 | D [o.e.m.o.s.c.s.OpcUaSubscriptionManager] [22:12:50]: Sending PublishRequest, requestHandle=6459928, acknowledgements=[id=65552/seq=404370]
INFO | jvm 2 | 2021/07/30 00:12:50 | Scheduling logfile maintenance. Last maintenance: Fri Jul 30 00:11:31 CEST 2021, events since then: 5036
INFO | jvm 2 | 2021/07/30 00:12:50 | Starting logfile maintenance. Max entries: 50000
INFO | jvm 2 | 2021/07/30 00:12:50 | D [o.e.m.o.s.c.s.OpcUaSubscriptionManager] [22:12:50]: Received PublishResponse, sequenceNumber=249177
INFO | jvm 2 | 2021/07/30 00:12:50 | D [o.e.m.o.s.c.s.OpcUaSubscriptionManager] [22:12:50]: onPublishComplete() response for subscriptionId=6
INFO | jvm 2 | 2021/07/30 00:12:52 | D [o.e.m.o.s.c.s.OpcUaSubscriptionManager] [22:12:51]: getTimeoutHint() maxKeepAlive=60000.0 maxPendingPublishes=2 timeoutHint=180000.0
INFO | jvm 2 | 2021/07/30 00:12:52 | D [o.e.m.o.s.c.s.OpcUaSubscriptionManager] [22:12:51]: Sending PublishRequest, requestHandle=32838933, acknowledgements=[]
STATUS | wrapper | 2021/07/30 00:13:25 | JVM appears hung: Timed out waiting for signal from JVM. Restarting JVM.
ERROR | wrapper | 2021/07/30 00:13:40 | Timed out waiting for the OS to forcibly terminate the JVM process, unable to continue.
ERROR | wrapper | 2021/07/30 00:13:40 | The scheduled restart of the JVM has been cancelled.
INFO | wrapper | 2021/07/30 00:15:10 | Wrapper Process has not received any CPU time for 89 seconds. Extending timeouts.
STATUS | wrapper | 2021/07/30 00:15:10 | JVM received a signal SIGKILL (9).
STATUS | wrapper | 2021/07/30 00:15:10 | <-- Wrapper Stopped
