Session Custom Properties not accessible
Hi, this morning I discovered that my tag bindings that point to session custom properties no longer work. When I click the Browse Properties button inside of my tag bindings, if I expand session, the only child inside is props, not custom or meta. I'm guessing some permissions were changed on accident but I don't know what. Any help would be appreciated!
I have had this happen a handful of times to me.
My typical troubleshooting route is as follows:
1.) Close view and reopen to reestablish the view config and try to bind again
2.) Close out of the designer and relaunch the designer
3.) Export the project and reimport under a new name
If none of those things work, I try and put the project on another gateway and see if it persists (Typically it hasn't for me)
Are you seeing the error overlay in the actual client or just simply the designer?
Reimporting the project did the trick! I was experiencing the error in both the client and designer. Thank you
