Is there a built-in way or has somebody come up with a way to log when users log in or out of an Ignition project? Ideally, I’d capture the user name and the IP address.
Thanks in advance for your help.
Never mind. This was ridiculously easy, as I thought it would be. Just missed the checkbox the first 50 times I looked at it.
Hi jlteel,
I want configure the session history, could you please explain it more?
Thanks in advance.
From the Designer, select “Properties” from the “Project” menu. Under the Project --> General settings, look for the check box that says “Enable Auditing.” Check it if it isn’t. That’s all there is.
Thanks jlteel,
