I am looking for the session property that return the host PC name. I have PCs that are on DHCP and could return a variable IP address. So, keying off the IP will not work for me.
Thanks for your help.
session.host, and it only works if the “Resolve Client Hostnames” setting is enabled and your network is setup correctly so that reverse DNS lookups work.
Understood thank you!
