Set client auto-renewal time after master gateway failover time
hi.
I'm doing a redundancy test. A problem occurred while forcibly failing over the master gateway.
There is no problem with master->redundancy progress, but it takes about 2 minutes and 30 seconds to recognize [lost master gateway].
Any way to set this time? (This is the time before [failover timeout])
There is a setting in the gateway redundancy config for failover detection. Check that.
The settings you mentioned
"Failover Timeout" are you referring to that?
