Set default schema in PostgreSQL for Tag History tables to something other than public
How do I tell a tag history provider for a database connection which schema to use for creating the tag history tables and storing the tag history data?
  • Example database config for “pg_ignition_dev”
    • Connect URL: jdbc:postgresql://[hostname]/ignition-dev
    • Username: devuser
    • Extra Connection Properties: search_path=historian
      • Tried this to set the historian schema as default but it did not work
    • Connection Initialization Commands: SET search_path = 'historian';
      • Also tried this but didn’t work
  • Example Tag History Provider
    • Nothing special here, just pointed it to the “pg_ignition_dev” config
How do I change away from public?
On your database connection properties add to your Extra Connection Properties field “currentSchema=yourSchemaName“ without quotes
