Set `historyEnabled` through scripting
Hi ,
I’ve found out the system.tag.browse has the historyEnabled variable.
https://docs.inductiveautomation.com/display/DOC81/system.tag.browse
I’m wondering how can I set the variables state through scripting.
You can simple write to the HistoryEnabled property directly:
tagPath = "Path/To/Tag"+".HistoryEnabled"
system.tag.writeBlocking([tagPath],[True])
Check out: https://docs.inductiveautomation.com/display/DOC81/system.tag.writeBlocking
For more info on the script function.
Thanks Brandon!
Worked like a charm
