Set tag values to 0 on comm loss
Is it possible to load 0 into tags if the device loses communication to the system
Without knowing your exact situation, tag value shouldn't be used in this manner. Every tag has a quality attribute, which should be a much better solution.
Quality Codes and Overlays - Ignition User Manual 8.1 - Ignition Documentation (inductiveautomation.com)
