But when I try to SET POINT using the expression IT does NOT work at all.
The setpoints works when I am using indirect tags normally to the C tag but when I use expression I does not do anything. I have Read/Write and Bi-Directional enabled and all that is needed to make it works - But when I try to set point IT DOES NOT work.
I know that I am not doing something correctly but what - and I am sure that I need to do a script - But how? and Where?
I would be happy if some of you experts can help me understand how to solve this and be able to set F values using C values directly.
Thanks.
That exactly what I did - BUT
you wrote “Expression tags cannot be directly written to. So in order to change the value of your Fahrenheit tag you will need to write to your Celsius tag.”
How can I do that if I want the user to see 55 and change it to 56 while behind scene it is 12.7 to 13.4
I don’t want the user to input 13.4 instead I want to enable only F values - i.e. 56 and not 13.4.
I think you guys are overthinking it a bit… just set up scaling on the OPC tag, it automatically goes both ways… if you need both values, just make two copies of the OPC tag, one without scaling.
[attachment=0]conversion.png[/attachment]
