Setting properties in a visionWindowOpened event has no effect
I have a popup window with a label. The window receives a single custom property, so I open it as follows:
window = system.nav.openWindow("popup_window", {"param": 123})
system.nav.centerWindow(window)
In the popup window, I have this code running in the visionWindowOpened event handler:
root_container = system.gui.getParentWindow(event).getComponentForPath('Root Container')
label = system.gui.getParentWindow(event).getComponentForPath('Root Container.Label')
label.text = str(root_container.param)
So the issue here is that when the popup appears, the label does not show "123" as its text.
I know I could bind the label text directly to the window custom property, but I'm trying to understand why this specific way of doing things is not working.
UPDATE: it does work when launching the project, but it doesn't work as expected when running in designer.
visionWindowOpened and Closed events do not fire in the designer.
