Setting up an Active Directory for an Internal-AD hybrid?
I’m completely new to setting up an Active Directory, but need to do so to emulate a clients set up. I am using Windows Server 2012. I am just trying to set up an active directory so that I can add some test users and roles so I can set up the security of the application.
In the Server Manager, I’ve set up an Active Directory Domain Services and a Active Directory Lightweight Directory Services, but I don’t see where I would add users, nor do I see where I can find the configuration credentials that Ignition needs to connect to one of the said AD (I’m unsure if both are required?).
I know this is only tangentially related to ignition but if someone can point me in the right direction I’d really appreciate it.
Found this for anyone else who’s been troubled by the same
