I want to add these two docker instances (or only the master) as agents to my Enterprise setup but i'm not able to select agent in the EAM configuration on the docker gateway.
I was able to set up communication between the docker instances and my EAM Controller
The Agent selection will be disabled if there are no running gateway network connections. The reason is that you have to pick an EAM controller from a remote gateway list during agent setup.
