Setting up gateway time script
I want setup a time script that i can run script for simulating running conditions. most scripts are event etc. Wondware has a scripting function called application script that allows script to be run on a cycle time you set, simulator to a plc scan time. im sure ignition can do this but i have not had any luck setting up the gateway time script.
Here's the user manual entry for the Gateway Event Timer Script if that helps.
If you have tried setting this up but have been unsuccessful, what have you tried (post the code)?
you can also set up tags in a "fixed rate" execution mode..
