Setting Up MySQL on a Backup Gateway
Has anyone come across any documentation specific to the installation and configuration of a MySQL database on a Backup Gateway?
The Ignition Gateway is very straight forward but I would like to insure that historical data is not lost if the main gateway crashes…
Not sure how to approach the MySQL database side of things..
Ignition redundancy does not understand master/backup database instances (and databases should never be installed on the same server as Ignition in production environments). You are expected to set up high availability database clustering outside your Ignition servers, using DB native technologies, such that both master and backup gateways can point to the DB cluster with a single URL.
Ah. So I should “move” the MySQL to a third machine and have them both point to the same instance?
Yes. And if you need a redundant DB, it has to be done internal to your DB brand. Often done with HAproxy or similar load balancers that track which real DB is "master" behind the proxy. Some solutions use floating IP addresses the move to the live "master". There are multi-master options in some environments, but Ignition isn't really equipped to handle that.
I will check with site IT. I think just a scheduled back-up of the database should be sufficient.
Thanks as always.
