Settings Record to reference a database connection
For a module I try in a record to reference a database connection.
What is the @FormField annotation to use ?
FormFieldType.REFERENCE or FormFieldType.SELECT or other ?
public record MySettingsResource(
        @FormCategory("MyCategory")
        @FormField(FormFieldType.REFERENCE)
        @Label("Db connection")
        @Required
        @DefaultValue(???)
        @Description("DB connection to use")
        String dbConnection ???
@FormField + @FormRerefenceType.
Example from BACnet:
@FormReferenceType("com.inductiveautomation.opcua.drivers.bacnet/BacnetIpLocalDeviceConfig")
where the reference type is the fully-qualified path to the type of reference (module id + resource type id). In your case ignition/database-connection I think?
