Setup SSL - Install Certificate help
Hello,
I am trying to setup SSL (https) on the ignition gateway server, following these instructions: Secure Communication (SSL / TLS) - Ignition User Manual 8.1 - Ignition Documentation
The file I received from "Issuer: Let's Encrypt" contains:
Certificate: (CRT)
-----BEGIN CERTIFICATE-----
content....
-----END CERTIFICATE-----
Private Key (KEY)
-----BEGIN RSA PRIVATE KEY-----
content....
-----END RSA PRIVATE KEY-----
Certificate Authority Bundle: (CABUNDLE)
content....
The setup on ignition gateway requires following:
- Private Key
- Certificate Signed By A Certificate Authority (CA)
- Any Intermediate CA Certificates (Provided by your CA)
- Root CA Certificate (Provided by your CA)
What is the mapping here? thanks
A CA Bundle isn't just one certificate. Take a closer look. It will be a chain of multiple certs, including the final Certificate Authority. Split it up.
I took another look.
content....
Content inside looks like a single string to me. How do I split it up?
I would use OpenSSL command line tools. (I always have to open the man pages when I use them, sorry.)
