I’m getting the following error when trying to run a new SFC.
Note Init is the first step in the SFC. Debug mode behaves the same.
Any ideas?
12:08:01 PM ChartInstance Chart ‘WortPriority’ aborted in ‘Script[Step:Init]’
java.lang.Exception: function ‘onStart’ not defined.
at com.inductiveautomation.sfc.elements.steps.StepScriptRunner.invoke(StepScriptRunner.java:42)
at com.inductiveautomation.sfc.elements.steps.StepScriptRunner.invoke(StepScriptRunner.java:34)
at com.inductiveautomation.sfc.elements.steps.action.ActionStep.activateStep(ActionStep.java:48)
at com.inductiveautomation.sfc.elements.StepContainer.onActivateRequested(StepContainer.java:125)
at com.inductiveautomation.sfc.fsm.element.ElementInactive.action(ElementInactive.java:33)
at com.inductiveautomation.sfc.fsm.element.ElementInactive.action(ElementInactive.java:8)
at com.inductiveautomation.sfc.fsm.StateContext.lambda$handleEvent$0(StateContext.java:52)
at com.inductiveautomation.sfc.api.ExecutionQueue$ThrowableCatchingRunnable.run(ExecutionQueue.java:136)
at com.inductiveautomation.sfc.api.ExecutionQueue$PollAndExecute.run(ExecutionQueue.java:111)
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)
at java.util.concurrent.FutureTask.run(FutureTask.java:266)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
at java.lang.Thread.run(Thread.java:745)
less
