All,
I was wondering if there is a way in the SFC to set a step number to jump to? For example, In a workflow the end user may be on step 200 but I would want them to repeat the last 5 steps because they have messed something up, so I’d like to at will set them back to 195.
Am I missing something, or can the SFCs not do this?
Mike
Hi Mike,
You can use multiple transitions to do this:
I had seen that in the videos but it doesnt really achieve what i need.
I would essentially have to loop that back in front of every action block and transition based on what step number I wanted to force it to go to.
Unfortunately, for the size and dynamic element (meaning sequence 200 could have between 1 and 99 steps depending on the workflow), I was hoping for something more along the lines of PLC jumping where you could put in a step number and it would reset back to that step.
