Is there a way to reset the parallel section cancel condition? The parallel condition is executing fine the first time. The cancel condition triggers and the parallel section exits as expected. Then I want the SFC to loop back to the Parallel section to restart it but the cancel conditions apparently latches once they were activated.
SAme issue here with no solution, have you found it already?
