I would like to take advantage of using [shared] templates so as to share templates across multiple projects on a gateway. But before I start down this path, I have a couple of questions:
- Are there any known performance hits from using shared templates vs. project templates? In particular when deploying hundreds or even thousands of instances of different templates in a project?
- Are there recommended methods (other than Find/Replace) for moving a library of “project” templates to the [shared] space so that template paths are updated for all template instances in a project?
Thank you
Dan
