I want to be able to share a window that was created in Ignition Designer with someone just as a viewable link. Is there a way this is possible? For more context, I have created a dashboard of data and I want to be able to share that dashboard with other people without them needing to setup and install Ignition. Is this even possible?
Certainly possible if you are using Perspective.
If you are using Vision then they would need to have the Vision Client (and Launcher) installed.
