Hello,
I am connected via 4G internet usb modem and VPN. When I try to exec client shortcut, I see an error (file attached).
What could be the cause of it?
Are you receiving this error when trying to launch the client from the Gateway Homepage? Or, are you trying to launch from an already existent shortcut on your computer?
I would suggest navigating to the Ignition Gateway Homepage and try launching the client from there if you haven’t already.
Thank you, it seemed to be client Java problem. Now everything is ok.
