Should the conversion-report.txt in .gitignore file?
Should the conversion-report.txt file be in the .gitignore file?
I had a clean working tree yesterday and shut my laptop down.
Then today when I turned it on and ran git status in my local repo, it said modified: conversion-report.txt.
I hadn’t even opened a designer or anything, why would this file change then? Should it be in the .gitignore file?
Did you found an answer on that?
You can safely ignore conversion-report.txt in your .gitignore. It gets updated on gateway restart when the project converter inspects for any 7.9 projects that need converted from the internal DB format to the 8.x file-based format.
