Show/hide the docked window
How can i hide and show the docked window with a button, or control element?
thanks you.
I don’t have any solution yet but I want to do the same. My idea is to move smoothly in the work space. However, if you just what to close and open, make your docked window closeable and add a button to manage this actions with a script. I haven’t test it by myself but it should work.
I have a solution to your idea. you have to use system.gui.transform function
This will not work since is applicable to components, not windows or root containers, but thanks
If you’re using vision, I’m not sure. But this is really easy in Perspective: https://docs.inductiveautomation.com/display/DOC80/Self-Hiding+Navigation+Drawer
