i have a svg and png images...i want to show the blades in that images rotating.
How do i go about it??
You'll need the blades, or at least a circle that includes the blades, as a separate element or component. if you want it smooth you should use css to animate it.
Eg in a p style, make it animated with 2 key frames, one at the start and end. In the start, in the background prop for example, set its value to:
;transform: rotate(0deg)
In the end key frame set it to:
;transform: rotate(360deg)
Apply the style to your blades object
Or follow high performance standards and don't animate it. Its distracting and serves no real purpose.
You can check one of the symbols that Perspective has.
I normally agree, but that's a pretty cool looking 3d render of whatever it is ![]()
