Show Tag name in vision client
I created a report which is dynamically works
I would like to show the tag name in my report too
How can I show the tag name? how I can access the tag name in the script
You’ll have to pass it as a string parameter into the report. Then the report can work with it like any other data item.
If you’re still using the tagAdress as the parameter that contains your tag, and your tag name is the last part of your string, you can add a script DataSource with this code in it:
data['tagName']= data['tagAddress'].split('/')[-1]
I couldn’t think of an easy way to do this via expression, but this should work at least.
