I can open the html URL I created from Google Chrome and see “live data” (there a still a ~5 second delay that I need to look into) from any PC on our network – Great!
Now the last step is display the stream in Perspective. I have tried loading the URL from the Video Player control, but it complains about “Cross-Origin Read Blocking (CORB)”. If I deploy the html page via the Web Dev Module in perspective then the CORB errors goes away, but it still gives me a “File not Valid” error (but no error in the console).
I have tried loading the video via a “Inline frame” in Perspective, and that works well (except for scaling of the video, which makes it hard to view).
I think next step is to try to add CORS headers to the webpage hosting the html page, but I’m not 100% that the correct path forward?
Thanks for the reply - yes we do have both http and https configured, but I’m testing using http at the moment, as I was running into the problem that you described when using https.
How does the html file come into play? I think hosting a page on the gateway that receives the stream from VLC on the other server would work, I haven’t tried that though.
You could use VLC on the gateway to re-broadcast your HTTP stream coming from the other server, then use that URL in the video player component.
Edit:
Actually i don’t think its necessary to re-stream, what if you just use (http://192.168.50.50:8181/stream) as the source for your player?`
If one of the forum big brains has more info or corrections, i hope they chime in.
Good idea, but the streaming server is running apache without any security... As far as I understand it, then it also the browser that will open the steam in perspective, but I might be wrong.
If i understand your setup correctly, i think you may be over complicating things. All you need is VLC to broadcast your stream as a HTTP URL, then use that url for the video players source. The only two scenarios i know where it would work in a browser but not perspective (assuming you have your streaming setup correctly) are incorrect permissions, and having TLS/SSH enabled. I never could get it to work with TLS/SSH enabled.
Yes you are right, I think I overcomplicated it a bit. I finally found a solution! I found a program called “ustreamer”, it streams 4k with almost no lag (less than 1 second), and it works without any issues with Perspective.
I just got the SSL certificate, and everthing works over https as well. I had to proxy though nginx as ustreamer does not support https by itself, but that was pretty simple to setup…
