Showcase API Tool - Various Issues
Today I went to use the API tool to manage licenses and I suddenly started having issues (it worked for months before). I started getting this error:
Vision Page
Error
I bypassed the script that was causing the issue (in this example the bypass is commented out):
However, now when I click on my licenses it says it cannot find the licenses:
Any idea of what is going on? I was going to try reimporting the API tool project thinking there may have been an update but it looks like that hasn't been updated since 2024.
Well, as a workaround solution I bypassed the logic which does the filtering. It's strange that it broke, but at least this got me working for the short term.
Change row[0] to row[1] in both places.
Something has changed with the Grants column appearing first instead of the product key.
Ignition Support Ticket: #150493
The backend issue has been fixed, but this is apparently only a bit of a bandaid - the recommendation is to switch to the Perspective project, which will be formally announced/rolled out soon:
Hi Paul
Can you share the Perspective project?
It's linked in the above post.
I mean the source code
Not my circus, not my source code, so I don't know. You'd have to talk to our sales engineering department.
My guess is no; they probably want this as a Perspective project precisely so that it's easier to own it internally.
I've been cleaning up the Vision project when I hit pain points. When I reach a non-embarrassing level, I will share it.
