Siemens 1200 device module not connecting
Hi all.
background:
Ignition system for our Brewery Building Management System.
Primarily Allen Bradley but i recently purchased the Siemens module to add some IO to a S7-1200 controller and had it added to our license. I enabled it and then went on to add a network s-1200 controller. The IP address pings on the Ignition network and I’m connected online to the controller with our network.
Under Configuration–devices–everything (Two Compactlogix controllers and a Red Lion protocol converter) shows connected except the Siemens device. The IP address of the controller has been verified in the edit tab.
I have a ticket out with IA but it’s been a few days.
Thoughts? TIA
Have you verified the “Considerations for 1200 and 1500 Devices” from the driver’s documentation?
I have. The only issue I may have is isolating the access level and the Get/Put items mentioed.
Where would I find these settings?
In the Siemens programming software. The 1200 and 1500 won’t talk to Ignition out of the box. (The latter has a built-in OPC server option, though.) Others on this forum have more Siemens experience.
https://support.inductiveautomation.com/index.php?/Knowledgebase/Article/View/29/0/connecting-to-siemens-s7-1200-and-s7-1500
Thank you. I went through and checked these but still don’t have a connection.
I saw something about only Tia Portal version 16 is OPC compatible…not sure if this is true or not
