Siemens Enhanced Driver S7 1500 loses all communication when an INT tag value drops below 64
Environment
  • Ignition 8.3.6
  • Siemens Enhanced driver — Symbolic addressing
  • PLC: Siemens S7-1500 — firmware 4.0
  • Affected tag: an INT written by the PLC, inside a UDT instance, read symbolically from an optimized DB (it's a "card number" used in a PLC↔Ignition handshake)
What happens
Whenever that INT tag holds a value below 64, the entire device connection stops communicating. Every tag on the device goes Bad and the connection reports as defined-but-not-established. There is no Gateway log entry, the tags just go Bad with the error "Communication with the datasource is defined but not established".
The behavior is:
  • Value-dependent — only values < 64 trigger it. >= 64 is always fine.
  • Total — it's the whole device that drops, not just that one tag.
  • Self-clearing — I don't restart anything. The moment the PLC writes a value >= 64 again, communication comes back on its own.
  • It's clearly below the script/DB layer: tag event scripts never fire during the fault (nothing in the gateway logs), because no value updates come through at all.
Steps to reproduce
  1. Symbolic-addressing connection to an S7-1500, INT tag in an optimized DB.
  2. Have the PLC write a value < 64 into that tag.
  3. The whole device goes Bad / loses communication.
  4. Write a value >= 64 → communication is restored automatically.
Expected vs actual
  • Expected: the value held by a tag should never influence device communication.
  • Actual: values < 64 reliably take down the entire device connection until the value goes back up.
I'm only using symbolic addressing, so I can't compare against absolute/legacy addressing — I'd be curious whether anyone sees this only with symbolic. Optimized writes is ON.
Workaround (currently stable)
On the PLC I add 100 to the number before writing it to the tag, and I subtract 100 in Ignition after reading. The on-wire value is therefore always >= 100, and the problem hasn't recurred since.
Questions
  • Has anyone hit this with Symbolic addressing on 8.3.x?
  • Is there something about INT values < 64 in symbolic reads/writes I'm missing, or is this a known driver issue?
  • What logs / device diagnostics should I capture to turn this into a proper ticket? Happy to provide gateway logs and a packet capture.
Open a support ticket with this information and let IA ask for whatever else they need. Include a link back to this forum topic.
Done, I'll post updates here.
Hi, check for plc siemens firmware , version 4.0 have a problem. Test with 4.0.4 or 4.1
Sadly I currently can't find the time to reproduce the bug and provide IA the material they requested. Updating the firmware is also not possible. I'll close this thread with no solution to the problem, sorry
