Hi everyone ,
I am reading long real data from Plc but full value is not coming correct in Ignition. Because I choose real not long real data type.
I wonder if long real is not supported ?
Thank you
Hi everyone ,
Thank you
Are you using the siemens driver or opc UA ?
If siemens driver the long is not supported yout will need to read it like to real/dint and merge it inside ignition
Hi, is still not possible to read Long Real with SIEMENS drivers?
I don't undestand why i can merge, can you make me an example?
Thank you
If you only need reading you could use this
