I am interested in using the Ignition OPC-UA Server with a Siemens PCS7 system (CPU 416-DP and CPU 417 processors) that uses the ISO-Protocol on the system bus. (Our configuration is similar to the configuration in this link - in particular see step 4) : http://support.automation.siemens.com/CN/llisapi.dll?func=cslib.csinfo&objId=23990630&load=treecontent&lang=en&siteid=cseus&aktprim=0&objaction=csview&extranet=standard&viewreg=CN I have contacted other OPC Server vendors and their software will not work with the ISO-Protocol and MAC addressing. Their products only work with TCP/IP Ethernet. Can someone tell me if I can use Ignition’s OPC-UA server with only a MAC address? (No IP addresses are used on our system bus.)
No, our Siemens drivers only support the S7 protocol over TCP.
