Siemens PLC Connection Details Not showing any statistics
I’m assuming this is a new feature to Ignition 8.3, but on a Rockwell PLC, it shows all the statistics, response times, throughput, etc.
However, for the Siemens driver, the monitored item count is at zero, and no graphs are visible. The Logs are working
We don't have any diagnostics/metrics for this driver. If we add some, they may be a bit different than other drivers, since much of the request/response handling is abstracted away from us.
