Hi.
We recently got our ignition connected to the S7-1200 PLC, but any and all tags added to ignition get
“[CONFIG_ERROR] null”
PUT/GET is enabled in the plc.
I have added tags like DB44,X122.0 which is a boolean in DB44, just to test, it gets last value “n/a”, and quality is empty.
How to gain access to the tags, any ideas?
EDIT: Now when i checked wrapper.log i find this:
INFO | jvm 3 | 2016/07/28 07:21:34 | WARN [CreateMonitoredItemsService ] [07:21:34,881]: Returning ServiceFault for request: [CreateMonitoredItemsRequest requestHandle=25814]. StatusCode=StatusCode[Severity=Bad, Subcode=Bad_InternalError]
INFO | jvm 3 | 2016/07/28 07:21:34 | java.lang.NullPointerException
INFO | jvm 3 | 2016/07/28 07:21:34 | WARN [OpcUaConnection$UaSubscriptionChangeListener] [07:21:34,889]: Failed to create 116 items on subscription 'Scanclass 'Default[default]'': UaServiceFaultException: status=Bad_InternalError, message=An internal error occurred as a result of a programming or configuration error.
INFO | jvm 3 | 2016/07/28 07:21:34 | java.util.concurrent.ExecutionException: UaServiceFaultException: status=Bad_InternalError, message=An internal error occurred as a result of a programming or configuration error.
[attachment=0]tag config errors.png[/attachment]
- must have been thinking about something else (like integer offsets)
