0sm0
1
Hi guys,
I have a s7-1214 hooked up to ignition via the S7-1220 ethernet driver and connected ok.
My issue is getting bits from the memory tags. Eg. M100.1… MX100.1 doesn’t work.
I can see DB tags and DB bits no problem. eg, DB50,X0.0
Has anyone dealt with the TIA portal software and these memory tags?
Cheers for any wisdom…
Tim…
craigb
2
Just tried it on my Siemens 1500 cpu which works the same as the 1200. Using TIA V12
Here the tag I use [demoplc]MX110.0
Don’t forget to set it to Boolean.
Craig.
0sm0
3
Thanks Craig.
I thought I was going crazy. Will give it another go tomorrow.
Cheers for the reply.
Tim…
